The trunk release latches on our Motor Trike Adventure (08' Gold Wing) are not functioning correctly. They opened all day long, then, when we finally got home - nada! When we did get the top trunk open with the "trunk-pop" on the remote keyfob, we removed the rubber grommets around the edge - they seemed to be causing some problem. From morning at 56 degrees through 254 miles later at 96 degrees..we think those rubber grommets might have expanded a little.
The release latch on the right side, underneath the top trunk, will not open the bottom trunk. We pulled the left rear side panel off below the passenger seat - found the cable, pulled it gently and got the bottom trunk to open. Making sure there was nothing in the trunk, closed it and gently pulled the cable again - now the bottom trunk won't release again using the cable or the latch.
Can anyone provide info as to where the threads are on this forum concerning this same subject - OR - provide fresh info? It seems I read that the cable can break. But I can't remember how to get to everything to replace it or maybe it just needs to be re-hooked properly. The cable is still connected to something - it didn't just pull loose and come out in my hand.
Many thanks to any/all info anyone can point at me! Jim
