low rear clearance Lehman trike
Oct 11, 2010
3
hutchinson, ks
I have a94 GW 1500 W/06 Lehman conversion has low rear end clearence I drag rear body on most drives. Any help in lifting it. Has progressive rear air shocks and get same ride height running 20 or 60# air. Any help.
I know there's a fix for the Tri Glide, But i haven't seen one for the Lehman.:Shrug:
You are saying the BODY drags. Trailer hitch or the EXHAUST drags. Tires rubbing inside fenders ??? How much weight are you traveling with ? Passenger and Rider ?
I also have the problem of the rear of the trike habgs to low and drag the trailer hitch every dip, drive way etc. There must way to lift this bike up. Is there something other than air shock I can use to get my rear up. Any help would be great. Thanks Gary
Same problem. I drag the exhaust alot! It just sits really low. I have been under the thing and don't really see anyway to jack the back up a couple of inches.
Dan2003
