Love Jugs or Cobra Exhaust or both
Pux
10+ Posts
Nov 21, 2019
14
12
Grand Haven, MI
Phil
Summer is here, and I am running out of projects for my 2010 TriGlide. I am thinking or either adding Love Juggs and/or replace my stock exhaust system with the Cobra Headpipes. Basically trying to reduce some of the heat and maybe improve performance? I have a Powerflo Air Cleaner, 909 Slip ons and a Cobra FI200R. The bike runs great, just hot on the right side especially. And while we are on the subject (or are we?); assuming I install Love Juggs (preference would be the Mighty Mites), standard mount, vibration master, or FMK? Thanks in advance for your help/opinion. Ride Safe!
If you were going to change the headpipes, I would recommend these:
https://www.fuelmotousa.com/i-20859...IDSON||model=TRI GLIDE ULTRA CLASSIC FLHTCUTG
Frame mounting the Mighty Mites is the best long term. Less vibration on the fans. Its not easy but doable. If not than use the vibration master.
Call Jamie at Fuel Moto . Pipes amd fans may help some but never found it stop that cooking my thigh feeling.
Try tuning the engine ;)
Here is a Report on how to cool down your M8- LINK
There are a lot of little, inexpensive things you can do (in the link above) that make a difference.
Between the two you listed, I would go with the Mighty-Mites at this LINK, UNLESS the heat you are feeling the worst is coming from the catalytic converter....then you'll want to de-cat you head pipe or get a new head-pipe. I would go with the Power Duals or the ones from Fuelmoto.
Old Road Dog
Pux you didnt list the breather bypass as one of your mods.DK has what you need. I've done all the mods to my Twin Cam and it's still hot compared to my M8. Hey theres your solution- a new trike!
Dhawk
