lehman trike kits
:GL1800:Welcome Steelman, I have an 05 Wing with the Lehman kit. Have owned it about 1-1/2 years and rode it for 8500 miles. have had no problems, ride and handling is great. I run 18 to 20 PSI in the rear tires, set the shock preload at 12 for 1 up, 22 for 2 up. You have to buy parts for the kit from a Lehman dealer, you can not buy direct from Lehman but that is not a big deal just find the closest dealer and they can ship you anything you need. I do most of my own service work so I have not had any dealer work done, but have not needed any. It is a simple set-up not a lot of working parts to cause problems. If you need more info feel free to PM me or call all my info is in my profile, I hope this helps. Ride safe Good luck. Buy and ride all you can Life is short. Jay A.:GL1800:
I really appricate the info. Its always good to talk with someone who owns or has owned one. Thanks
Steelman I have an 07 Monarch II with over 35,000 on it. They're very dependable and trouble free. Just give the u-joint a shot of grease every time you change the oil on the bike and you're good to go. The biggest issue with the trike is if you're having yours done is to make sure you have a good installer. A good installer is everything. A bad install will give you headaches that never end. Feel free to PM me also if you have any questions.
Trustme54
