lehman trike kit
Aug 31, 2012
4
casselberry florida
have a lehman trike kit on my 1998 1500 and can't find any info on it. like how can you tell what year the kit is or is there a parts break down in case I need to fix something or how often to change the rear end fluid? would like to hear from any one with the older styles. thanks and hope you all had a great veterans day.
Look on the frame on the underside of the kit added by Lehman. You will find a metal tag containing information from Lehman. Check out their website to contact technical support with your specific questions.
thanks for the info. I needed some info about gaskets tires brakes and drums which i was able to get from lehman now that they are back in business. also needed to change the tires even though they have less than ten k on them because they are 6 years old with no cracks or wear on the tires. it has 245 60 15 on it and lehman said that was what they original put on but you can run 205 70 15 as well.
Lee H Mann is a forum member and as his forum name suggests he is a knowledgeable guy when it comes to Lehmann kits.
Lehman Trike kit.
I thought I’d give my input albeit. I purchased in 2014 a new Harley Davidson Ultra Limited in Daytona Blue Pearl. It has been the best of all the Harleys I have owned bar none. It is even better than the 2011 Road Glide CVO I previously owned. Now it’s time to step up to 3 wheels and Lehman was my first choice. Mainly because of their relationship and experience building the Triglide for Harley Davidson. I have chosen the Trinity LLS because I want independent suspension and I like the Triglide look.. I dropped it off on 10/09/18 and it should be done by the mid November. I will pick it up at the factory in California and look forward to sharing my experiences. So far they have been great to deal with and very supportive.
dyno56ca
