Lehman Renegade Kit Air Fill location
YumAndy
Mar 8, 2024
22
25
Yuma, AZ
Andy
UPDATE: found the lil buggers... thanks everyone...
I have a '99 Ultra with a Lehman Renegade and i cannot for the life of me find where the air shock fill valves are??? I dont see good and looked the other day underneath to see the airlines... Can anyone tell this dumb Norske where to look?IMG_2164.jpg
Maybe this will help.
I found this info on page 21:
See Fig. 5. Air valve plate for front and rearshocks must be relocated. Recommended loca-tion is on right side of trike behind top bolt onelectronic control module. Re-route air lines to fit
found em, they were under LH cover behind the elec shifter control module but i dont find any
guides as to how much air do you put in ??
The air pressure will be a personal thing. It will be different for everyone as there are many variables. You will need to experiment to find one you like. Try starting out at the testing pressure of 20lb psi. Then try increasing a little maybe 5-10lb at a time and see how it feels. If the ride gets too stiff, just back it off. If it's not "plushy" enough, add some more.
Make sure though to find out the max pressure for your particular shocks because you don't want to go over and blow the seals. Hopefully someone with that knowledge will be along shortly.
Besides the shocks, another thing that really affects the quality of the ride is the tire pressure. It is common for those to be overfilled especially the trike rear tires. Many think they need to be aired up quite a bit. But remember, those are car tires and rates to handle the weight of automobiles. Trikes weigh significantly less so do not require the same pressure as if the tires were mounted to a car.
And just in case you don't have this manual, it may be of some help to you. Click on the PDF link below to download it. It's a Lehman Technical manual.
  • techbook-master.pdf
Dragon warrior
