led's on stallion mirrors
dancerjim
Contributing Member
Aug 7, 2010
96
2
Orange, Ct. USA
Does anybody know where i could find the thread that has the info on putting flex strip led's on the stallion mirrors, or has any of our stallion owners put them on?
I just installed LED's to my front turn signals. I tapped into the wire loom just inside each turn signal wiring. Mine was easily attained by going under the hood area.
I did have to cut into each wire for the turn signals to get the 18gage wire to make contact. Those wires are extremely fragile. Works great and now I will know when my turn signals are on. pepper
Sorry...no. I just installed separate LED's to each side of the hood area near the windshield. Mine are approx 3 inches long and are red in color. Works great.
Inside the black plastic loom are 2 wires, on the left the purple/white is the hot and black is ground. On the right the gray/yellow is hot and black is ground.
Just rewrap the loom and stuff the wires back inside.
Remember to loosen the 2 phillips head screws on the sides so to make it easier to slide your LED wires into place. Then re-tighten when done.
Hope this helps
El Cabron
