LED Headlight?
Oct 19, 2014
943
661
Rochester, NH
Dennis
Has anyone who has a Yamaha Venture replaced their OEM headlight with LED light? Also have you changed your Passing Lights with LEDs?
IF so, could you provide info?
John, that was for the passing lamps. did you need an adapter for them or where they plug and play? Did you replace your headlight?
The other day I looked them up and it says they fit my bike... but when you pull up the list of bikes, the Venture is not listed.
For around $95 they have the headlamp and passing lamps with the adaptor for the headlights to keep them from flickering.
Thanks for the info
Yes, I did the headlight and passing lamps.
Passing lamps require running wire. But headlight, lots of work, cutting headlight bucket housing to make it fit, and to use stock headlight adjustment.
It is Alot Brighter, well worth the many hours spent installing.
Later-
Thanks for the info
I got all three. I use a foam tape around the passing light but no mods for the headlamp. Some of the guys in the road star clinic found passing lights that came in 4 or 4 1/4 models on ebay
Stitch61
