LED Headlight / Passing Lamps installed
Jul 15, 2011
247
3
Wichita, KS
Today I installed my new LED headlight and passing lamps. These are the Truck-Lite brand, not the HD brand.
Install took me less than an hour.
Here's a pic showing one of the passing lamps installed. Notice how much whiter the light color is.
Both passing lamps installed. The halogen headlight just pales in comparison.
Now here's a trick to modify the headlight bezel if you're using a "french" or "visor" trim ring. Harley wants you to install the OEM trim ring underneath the new trim ring. I find this to be a crappy way to do it. However, the new trim ring is too loose without it.
So, what I did was install a series of small screws around the headlight bezel. With a small nut on each side, I can "extend" the screws out as much as needed. These screws fit inside the lip of the new trim ring, locking it onto the bezel. Another benefit of this modification is that the new trim ring installs cleanly with absolutely no gap at the bottom.
Here's a couple of pics showing all the lamps installed.
Most of my riding is during daylight hours and visibility is absolutely paramount. I think these LED lamps give me much more visibility than the OEM halogen lamps.
The lights are standard size and are sold by Kuryakyn. Seven inches for the headlight and 4.5 inches for the passing lamps. I buy all of my aftermarket accessories from a local indy dealer that I've been friends with for years. If you want his contact info, just PM me and I'll respond back with his contact details.
Big improvement JohnC. What have you done to your Rear fender light's? We are looking at different option's since removing the pizza box. Looked at BAL, Custom Dynamic's and Truck Light. I have priced Harley's replacement LED's as well. Even looked at the LED replacement Bulbs that supposedly rotates and flashes??????? Any help would be great, Thanks.
I have not made any changes to the rear lighting at all. I've been looking at adding some kind of third brake light to the tourpak but haven't decided on anything as of yet. The BAL tailights get a lot of great reviews but they are pricey. If you haven't already, check out Custom Dynamics for some lighting ideas.
I spoke with a sales rep at Custom Dynamics this week. The ones she suggested were simular to BAL and cheaper by about 50.00 bucks per light.
Marks2024
