leak
May 13, 2018
104
100
Princeton, WV
David
2012 tri glide leaking from rocker box. heard hd had a new gasket fix for this anyone no, are hd gaskets as good as after market.going to change both heads while at it. any input .
Had old Shiney's gaskets swapped sametime I did stator oil leak 2017---19,000 +/-
You say it is leaking from the rocker box but are asking about head gaskets. These are two different things. Might want to verify exactly where the leak is before tearing into it.
going to change front rocker gasket and rear rocker gasket is that clear enough!
FlorineGri
