Is "old" oil safe
I would use it in a New York minute.....But if you have any nagging doubts toss it, Probably cost you only 4 bucks 5 years ago, That is with not factoring in inflation..:Shrug:
Unopened oil
I see NO problem in using that oil........I’m sure many of us remember oil coming in ‘paper cardboard’ containers.........what a minute, I need to check my garage!
:Coffee:
Us RETIRIES are getting O L D.........(but still enjoy the ride)
Depends on storage..
Pour it into another container before dumping it into the bike in case there is any moisture or water build up in the container.
We see it all the time for our tractors (fluids are stored in a non climate controlled shop) & will usually have some "sludge" inside the container. We pour into a fresh bucket to filter out the crud before we dump it into the equipment.
:Coffee:
Ha! I remember when you had to use a can opener( or a bayonet) to drink a beer.And it came in steel cans(blah). NO pop tops on anything.Things were so bad we had to read clocks with little hands on them.No digital like kids these days need.And things were so tough that women only shaved thire legs and armpits. Can you believe it?
I doubt that a sealed bottle of Syn 3 would go bad but what is the point of even having to worry about it? For $10-11, you will likely experience greater piece of mind by just pitching the old oil and supporting the ridiculous price that Harley is getting for a semi-synthetic oil :p Our engines cost on the order of $7-8k and I can't see the logic in trying to save a buck or two by putting such an expensive engine at any risk if that is possible. Oil is relatively cheap, engines are not. The last point that comes to mind is that Harley may have improved the blend in the past 5 years and you would be missing some possible advantages of the newer oil formula?
Just use the damn oil ! ! If the rating hasn't changed. Don't remember when it changed last. Doubt it has in the last 5 years.
One bottle isn't going to hurt anything. Why didn't you use it in the last 5 years? Don't tell me you haven't changed your oil in 5 years. :D
Or carry it as an emergency top up. I always carry a vacuum sealed bottle on my long trips - just in case. Only needed it once for a friends bike years ago.
I would use it
If this oil is sealed, I'd have zero problems using it, after all it sits in your bike motor for a year, and it never hurt anything!
But if you want to throw it away, please send it to my address, and I'll dispose it for yea! :)
Ronnie
Interesting thread.....I've had oil on the shelf in my garage for longer than five years (still sealed) and never thought twice about using it in my vehicle. Not sure if it's sealed, how it would get moisture in it or become contaminated but maybe.........:confused:
Wouldn't bother me to use it, Even if it had moisture in it as soon the engine gets hot it will burn it off anyway.....And heres the ''BUT'' If someone is worried about using it then Monsters of the Id take over, And then every imagine sound or hiccup will be attributed to the oil......:xzqxz:
Thanks for all the good replies! Y'all put up a lot of good info that I hadn't thought of. That's why I like TrikeTalk so much, seems like I have found a bunch of new friends that I can get advice from.
And I forgot to mention that I had it in the garage as an emergency spare in case I discovered during my pre-ride check that engine or tranny was a little low and it was Sunday with no place open to get any. Thanks again!
Harley used to put out tenders each year to oil companies to make their oil to their engineers additive package
The MSD sheet for Syn3 calls it a BLEND oil not a true full synthetic unless this has changed I dunno for sure
I am happy to see this NOT going sideways like MOST oil threads go:p
When it comes to oil its always best to play it safe. Only buy the oil promoted in the ads from the trade driven journals with scantily clad models that subconsciously suggest they will sleep with you if you'll use the oil she's hawking.See- makes the choice easy.
I always use the Oil's that the Girls at Hooters recommend....And i never had an oil related engine failure...:Shrug:''
I actually buy oil when it goes on sale, and I buy large amounts of it...I have in my garage NOW approx 30 quarts of oil , and never had a problem using it, even when it has sat for years..I'm an oil changing fool on all my vehicles, and probably change oil more then the average person...
I have a heating/plumbing biz, and need to keep my trucks running in tip top shape all the time/so oil/filter changes I do all the time, same on my motorcycle. Every 2,000 miles..
Ronnie
Crap I got a quart of some oil my Dad left before they moved many many years ago. Its the old round can that you push the oil spout in.
I would use it in my lawnmower :D
I think the oil may be like the water you drink......probably a million yrs old give or take a few hundred thousand! lol......seriously, if there is any condensation, pour off the water. I do not know if the additives degrade after time. Maybe that is where the 5 yr. figure comes in?
That is what I would guess;)
Sell it on E-bay for lots of $$$$ as a collectors item. Like Harley just did with their reproduction oil can. :)
Ronnie
I also buy by the case (cars and bike) and normally have 2 cases in the garage at all times. I change twice a year for normal riding (5K each) plus a 10-40 change for winter riding (an additional 500 miles).
To me 2K miles is way too soon for syn oil - for dino oil I would though.
Me, I like to buy my oil one bottle at a time, That way it gives me an excuse to go for a ride....So by the time i ride to get all the oil and then the filler and then O rings, I have put on enough miles so i'm ready for another oil change ....Rinse and repeat.........:xzqxz:....:)
I would use it in a heart beat.
As long as it has been sealed, go for it. Maybe use it in the trans if you use syn oil. I use Redline in mine.
dyno56ca
