Is anybody a Mechanic ? (I've a car question)
Jul 24, 2014
137
70
Atwater, CA
Thomas
Off Subject, but ---
My Daughters car wont start and is showing 6 codes. One of each of the coils. Can I replace just the coils ? And not the PCM/Ecm ?
I was told, all six of the coils would not go out together. Probably One and, and it damaged the PCM. Replacying the coils, wont help the PCM. Replacing the PCM, and not the coils, will damage the new PCM. Hence I have to replace BOTH coils, and PCM together. (Parts alone are close to 1000. Any thoughts ?
Not a mechanic, but I would suspect either the PCM or a wiring harness issue. I can't see all coils going out at once. There should be a way to test the coils, but I do not know it.
There are times when the dealer has an advantage & electrical troubleshooting is 1 of them.
It also helps when your seeking advice to tell us the name of the patient. I take it it's a 6 cylinder.
Highly unlikely all 6 coils are bad
What kind of car is this
A crank sensor or cam sensor will shut off the coils with out always throwing a code
More info and I can maybe help you figure this out
You can test the coils with an ohm meter
I am a retired ASE certified tech
The coils fire after a switching device like a crank or cam sensor phases
Like points and condensers did years ago
I have never seen all coils go @ the same time
Not to say it cant happen
Your local parts store should have a code reader(some rent, some you have to buy) that you can use to see what codes it's throwing then look them up to see where to start. Most cars made after 1997 I believe have OBD port under the dash, usually near the steering wheel. Is it just not starting or was she driving it and it quit? Make, year and model will help.
Well as retired auto tech, I'd say bring it to a dealer. If you waste a 1000 for coils that probably won't fix it you'll end up there anyway. Code numbers are important for diagnostics. And although there are codes common to all cars, some are specific to your model.So make model year are a must.
Just remember that certain part failures will set off the domino code effect. Some coils come in sets, others have individual cylinder coils. You will need a real code reader to determine, not those Mickey Mouse readers.
Maybe a ground problem, seems that is a common complaint on a lot of systems these days.
Very good tip
Easy for high mileage cars to have grounding issues
Easy to check with a test light also,
Connect alligator end to battery
Now with pointed end lightly scratch all metal surfaces on engine, transmission, any where you see metal under the hood
If you have a ground the test light will light up
Next, if you really have the time and a good ohm meter you can check closer to see how good these grounds are
Google and model specific forums can be a good source of information. Just watch out for the "Internet French Boyfriend" experts!
When approached with a skeptical attitude, many gems of knowledge can be found.
Dude, that question, accompanied without make, model, engine of her car tells me your way over your head here. You need a shop you can trust to check it out right. Any component (anything with reference voltage from the pcm) in your fuel injection system can short out the pcm shutting it down but will not burn it up necessarily. If it has one coil shorted I would unplug it and try to start it up.
SOP On forums........Ask for help without adding enough pertinent info on the vehicle to get the help needed, But i Guess.....It does....Keeps everyone guessing i guess.:xzqxz:...:laugh:
Ram has a recall on my truck's brakes but no fix. Say they may fail at any time. We just finished a trip to Washington state hauling our cab over camper and two Spyder RTLs in an enclosed trailer, little over 16000 lbs cgvw. I was definitely thinking about that unresolved recall.
ksatrat
