SouthportFLRT
60+ Posts
I probably should have "searched" to discover if this topic has already been covered in the Forums but alas...I have not. Watching on YouTube (the world's source for answers to problems that may or may not exist) Gixxerfoo and HarleyGeezer1954 have both discussed the issue/problem with the stock H-D intake manifold being manufactured with composite plastics.
Per their perspective and more importantly the possible historical perspective that due to the heat generated by the M8 motor and the constant cycles of heat/cool the plastic has an eventual problem with cracking thereby creating a major issue with throttle response and riding in general. The Screamin Eagle aluminum intake manifold can be bought in both 55mm and 64mm sizes. The original plastic manifold is 55mm. H-D parts website states both will fit those of us with the M8 motors.
S&S also manufatures aluminum intake manifolds for a few dollars less...thru Parts Giant.com. I do not have any issues yet but thought I would inquire if others have possibly experienced this problem. Aluminum intake manifolds (55mm) are approximately $200.00 plus the cost of installation....but it seems like a rather straightforward swap to my non-technical, non-mechanical mind. I could very well be wrong.
I am a retired Pharmacist not an automotive mechanic. H-D also claims a retune will be neccessary which I truly doubt if one simply swaps a plastic 55mm for an aluminum 55mm. I am certain asnwers to this inquiry will be forthcoming and I look forward to discovering what others have done. Again...my 2019 M8 114 is not in dire need but I would rather prevent a problem than fix one. The very reason I had a Fueling Shorty Sump Plug installed during an oil change. Tech did not charge any labor for that because he said it took longer to read the simple instructions than doing the actual installation.
