Anyone on this forum in the Atlanta area installed the 3M film. I've read the instructions and I should be able to install the panels, however, I'm willing to pay someone to put them on. Of ourse I old need to see their work.
give it a go, its only difficult when u get on radius areas,,, at some point it is removal if u dont like it
i prefer the film that is removal,, cant recall the name at this point,, do a search. u order and cut to dim.
BTW nice ride.
This film is not hard to install all you need is a squegee and water. If you wet the fender and apply the film it will not stick with the water between surfaces. Position film where desires and work all of the water and air bubbles out with the squegee starting from the center, if you are not satisfied with something lift it off add more water and try it again it won't really stick till it is completely dry between the fender and the film.
