Improving Roadglide 3 Ride Quality??
If you are having a rough ride try 22-24 PSI in the rear tires and 0 for rear shock adjustment, if you are riding 2 up that will change to +10 or more
The rear tire pressure seems to make quite a difference, we've run 22# in the rears on both Triglides for many years. As far as shocks go it will take a lot of fiddling with the numbers on the stock ones, the numbers in the book are way off of reality.
I'm going to try 22 and see it was at 26 rear and I do have spring at 0 any more was rigid. Thank you
I suggest you ride it with the lower air pressure and see if there is a noticable improvement in the ride quality.
nmbr1soonerfan
