I won't be doing business
May 23, 2013
201
38
Mackinaw, IL
Howard
I won't be doing business with Niehaus Honda in IL. anymore. They changed my fork oil and then the seals started leaking and the said it wasn't their fault and wanted to charge me to change the seals. They also by-passed the secondary brake cylinder instead of replacing it because of a recall. They did in up changing the secondary and the rear master cylinder after my brakes locked up.
Secondary brake cylinder... Isnt that on the anti-dive valve on the from left fork??
The Secondary Master Cylinder(removable) is mounted on the LEFT fork and has BRAKE lines going to it.
The ANTI-dive is part of the the FORK (Helps control front suspension) -- the ANTI-dive is often disabled.
They are not the same thing.
tony29
