I have a trike I have been working on for a year now and It's almost done. We started doing the rear brakes and now we have problems. Had an axle seal leaking so I went to M. A. Motorworks and picked up an axle seal kit for a 67 swing axle. fits 46 - 67 swing axle.
When I got the hub off that holds the seal I find out it does not have the little drain holes at the bottom. Took it to only local vw shop and was told it was from a 68 IRS axle. Since then I found out they were from 58-64 hubs.
Now I need to ID this unit to figure out what to replace. The numbers on the side (stamped in) are: 4891188.
Also, I pulled the other drum off to find a puddle of gear oil in that side as well. I need to know if I should start looking for the right seal retaining hubs or if the seals are the same?
I'm stumped.....:Shrug:
