How to change CSC rear alxe seal
Feb 3, 2015
10
2
Wilton IA 52778
Has anyone changed the rear axle seal on a CSC conversion on a 1500. I believe it has a 8 inch ford rear end. Any help on the process would be appreciated. I called CSC and they told me the axles were built by Currie Enterprises and they did not know a lot about the assembly of them. Thanks Jack :)
Assuming it is a solid axle rear end and you are asking about the axle seal and NOT the pinion seal--- internet search for "replacing axle shaft seal ford 8 inch differential"
Thanks for the info. I thought about that after I posted the thread. Guess I should think before I ask. :)
Vinny1007
