How Does Hannigan deal with the Compressor on GL1500 conversions?
Aug 22, 2024
34
57
Oneida, TN
Paul
I have a 1995 GL1500 with a 35th anniversary Hannigan conversion.
From what I have read on here I think Hannigan uses a manual adjust shock for the rear suspension.
what do they do to the compressor onboard? mine will run and it actually gives me a pressure reading if I operate it like I am adjusting the suspension. I can raise and lower the pressure on the dash. if I try to use the button that was to supply air to the air hose connector that used to be in the saddle bag , it won't run. I am wondering if there is a hose connector somewhere I am not seeing of if Hannigan just plugs the shock line ? I would love to connect an air hose to it so I could use it for tires.
any help on where to look for the connection would be helpful
thanks
The hose to hook to to air up tires just hangs free.That said someone may have tied it to the frame.I think it usually has a valve stem cap on it.I think I have the hose that hooks to that still in the pack.Be careful when reading about suspension adjustments that that the info you getting applies to a kit on a 1500 and it applies to your model of conversion.
Stitch61
