How do you remove antenna. I want to replace with Stubby on my 2014 Goldwing Trike
gwright
10+ Posts
Feb 23, 2018
12
5
Soddy-Daisy, TN
Greg
I'm wanting to order a shorter antenna. I haven't received it yet. I went out on You-Tube but can't seem to find any information. My Harley had a set screw. Turned it out and spun off the antenna. I don't see any set screw on the Goldwing.
Probably very simple but wanted to ask before I ordered? I can't seem to find any install instructions on the product website. Add-On Motorcycle Accessories.
Thanks in advance
Greg
There is a lock nut just under the foldover part and you can use (IIRC) a 14mm wrench. Its not a traditional nut but just has two faces that the wrench will fit. It shows up as part #16
tony29
