You'll have to remove the instrument cluster from the bike to do so.
If you don't have a copy, I'd suggest picking up a copy of the FSM. You may be able to "cheat" this method a bit by utilizing a set of rake kit installation instructions since most outline how to get the cluster out of your way in order to do the rake kit.
I would also price a replacement lens as well, may not be "worth it" in relation to cost for the part. Knowing Honda it's probably $100 just for the "plastic" lens that protects the gauges.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
