You will need to start with the serial # of the transaxle to determine what you have now. This is assuming that it has never been modified, a rare creature these days.
Spend some time reading the older posts here and you will pick up a lot of info. The R&P issue has been discussed in the last year.
I had a IRA trans built for my swing axle using a 3.88 R&P and a .082 4th gear. The .082 is out of a bus and higher then the standard IRA 4th gear. I believe that is the highest combination you can make using stock parts.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
