Help with a Clicking Sound
Apr 20, 2014
56
21
Central, FL
Walt
I have a homemade outrigger style trike 04 Harley Electra Glide.
I have a Clicking sound coming from the left rear outrigger wheel area when I go into moderate to hard Left Turns.
I removed the wheel and checked the area nothing in the way so I checked the hub and thought it must be a wheel bearing, replaced the bearings. Clicking still there...
I have jacked it up pushed, pulled, punched and kicked everything I could and can not find anything that may be causing that noise. Rides fine no wobble or anything just a noticeable clicking sound in left turns only.
Any suggestions? My brilliant son told me don't turn left.:gah:
Hello,
Is it a possible crack, or weld that didn't penitrate?
And on left turns, pulls apart enough to "click"?
Or, just a loose nut/bolt?
Try looking in a spot you haven't checked yet....Maybe its not coming from the rear, and instead resonating up from the front...:Shrug: Been there found that....
I know this is not the same, But I once had a ticking/rattling sound from a car dash..
Drove me crazy [I haven't returned to normal yet :xzqxz:] it would only do it at certain times, Found out it was the key fob hitting the steering column..... :gah:
Well I found the culprit. The bolt backed out of the belt pulley and was hitting the lower shock mount on left turns. The bolt backed out far enough yesterday while I was going down the road to hit the shock mount and shear off. I just left my driveway when I heard a snap, I turned around and went back to my garage, Checked the bike and saw the hole, now to get a easy out and order a new pulley.
You might be able to tap it out with a sharp chisel and a hammer, By tapping it counter clock wise....I can't tell you how many nuts bolts and studs iv'e gotten out that way... The last one i removed that way was on my Tri-Glide's steering stabilizer where it mounts to the engine head... [9-1/16 bolt] Sheared it off flush with the cylinder head.. 3 or 4 well placed taps and it spun right out...
Just to add e-z outs are harden steel and they can and sometimes will snap with any kind of lateral pressure ...
I've seen this done AFTER an E-Z Out snapped of on an exhaust manifold stud.
tap out broken bolt
I usualy use a hardened punch and a hammer to tap out bolts but this didn't work on my last bb it had been glued with thread locker I guess I then drilled it and used a easy out but it broke so I drilled it again and broke another easy out .I quit after that and it is still in until I can get at it better. It just might stay in there . it wasn't:AGGHH: holding much any way:mad:
You know if there was a list of 'Oxymoron's ' #1 would be Military Intelligence.
And coming in close behind at #2 would be EZ-Outs....:gah:
Left hand drill bit.
Find you local Snap On guy. He will probably have some left hand drill bits, that's right they are made to drill in a counter clockwise motion. Have used mine several times, if it does not get the broken bolt out you at least have a hole for an extractor, Snap On also has the best extractors I have used. Perhaps a little pricey but worth it.
Update:
removed the rear wheel last night. All 5 bolts that hold the rear pulley on were snapped and I would have to heli coil all 5 holes, So I did the next best thing told my wife I need to go shopping for a new wheel.
Almostagamer
