Hello from North Mississippi
Just wanted to say hello, new to this form. I just purchased a 2010 Goldwing with the Champion conversion. Can anyone tell me what air presuure they air running for the best wear and ride. Thanks in advance.
Welcome to Trike Talk! :wave4:
I run my front tire at 36 lbs and the rears at 26 lbs. That's what works for me, others will share theirs, I'm sure.
I have a 05 Wing with a 2012 Roadsmith conversion. I run my front tire at 38 and the rear tires at 20.
And welcome to Trike talk from Central VA! ThumbUp
I run at BT 45 on the front mounted in reverse with 41 LBS and 28 LBS in the rear tires. Some folks like a softer ride and deflate down to 26 or 24
I also have a 2010 GL1800 with a Champion kit. I have a BT45 on the front that I inflate to 41 PSI and in the rear tires I go with Champions recomendation of 20-25, usually around 22 PSI.
Hello Johnny and welcome to the website from the U.P.of Michigan. Congratulations on your new ride. I believe your question has been answered but if any more come up don't be afraid to ask.
Welcome to TT - also from north Mississippi (Olive Branch area).
2008 Goldwing - run 40 in front and 24 in the rear.
I would run at lease 36-40 in the front and just adjust the rear to your desire suggest you start with 26 and work down to no lower than 22.
Ride safe and often.
FlintM
