Hello From Missouri
Nov 4, 2015
2
Kansas City
Just wanted to say hey. Was looking for info about my Tri Glide and found this website. I have some questions regarding new exhaust and what people would recommend. I'm looking to go with a set of 4" Rineharts with true duals and stage 1 breather. Should I take the trike to a dealership to have them installed so they can adjust the air fuel at same time?
Welcome to TT from Florida Andrew, I'm sure some more knowledgeable folks than me will be along to answer your questions.
First congrats for finding us. Rineharts are great but they do have a bark to them. Careful with the true duals you might end up losing some low end torque from the difference in the pipes of a true dual. A 2-1-2 systems has been a better recommendation by many. Changing exhaust and a cleaner you really should add a tuner to it and have it tuned for the changes. (In my opinion only) if I was going your route in parts I would use the 1.75 baffles in the mufflers. That should help some with the torque loose by the true duals. Hopefully others will jump in here and render their knowledge.
Welcome to Trike Talk from SEMO, glad to have you on board. I can't help on your question but Gorilla is very knowledgeable on these type of questions. I'm sure you will get others to add their 2 cents.
Welcome to TrikeTalk and hello from the other side of the state. I agree with Gorilla on your setup. Look into the Fullsac CX 2-1-2 headers or their Sportpipe. They will keep the low end torque on the engine much better then the true duals, been there done that. I'm running the Fullsac Sportpipe with SE Fatshotz, the TTS-100 cams and tuned it with the TTS tuner and lovin the results.
Welcome to TT from WV. I am running 2-1-2 Fuel Moto ceramic coated header with Bassani 4" Megaphone slip on with 2.5 inch baffles, Fuel Moto A/C and power vision tuner. Great results IMHO. Lots of choices especially with slip ons. Good luck in your search and keep us posted.
thanks for all the info guys im honestly stuck on what im going to do now. talked to a guy at Harley today and not sure im going to go with true duals. a lot of research to do lol
OATMEAL1897
