Headlight modulator
I'm using a headlight modulator by Kisan. Their unit plugs into the headlight bulb base. Disconnect the wiring harness plug from the bulb, plug in the Kisan unit to the base of the bulb then connect the wiring harness plug to the Kisan unit. Then all you have to do is install the photo sensor at a location on the bike where it can sense sunlight. I drilled a hole in the top of the headlight case and installed the sensor there.
DuneRider
