HD Deutsch Electrical Connectors (A short video explanation)
MDO
Oct 11, 2017
5,099
3,125
St. Louis, MO
Michael
Dis connect the battery when ever working on electrical, don't forget to put the weather pac seal on, don't force the connectors, if it does not snap together with an audible click re check every thing. Another good find Michael, this should be a sticky;)
  • Like
Reactions: MDO
I had seen several posts where people were having problems with the connectors.
I went out and tested it on the aft lighting connection under the seat & it worked well. I will need it when I wire my LED tail light.
I went out and tested it on the aft lighting connection under the seat & it worked well. I will need it when I wire my led light.
I like a bit of dilectric grease on the pins and the lock tabs;)
  • Like
Reactions: MDO
OleCat
