Harley Part # 69200042A Review
Sep 16, 2009
805
68
Myrtle Beach, SC
Tom
I just installed the Harley part # 69200042A Tour-Pak® Brake Light/Running Light/Turn Signal Conversion Kit
Turn signal module adds an auxiliary brake light and turn signal function to your Original Equipment Tour-Pak® rear lighting. Red lenses glow when the headlamp is on, and increase in intensity when brakes or turn signals are activated. Easy-to-install, the kit simply plugs into your existing wiring harness
I will say its a nice plug n play harness that is fairly simple to install that gives you added visibility on the rear of your bike or trike . But, if I would have known before hand that the 4 Way Emergency Flasher wouldn't flash the tourpak lights I would have not bought this wiring harness. Its printed at the end of the installation instructions that the 4 Way Emergency flasher will not operate the tour pak lights.
I would have gone with the Ridetime Technologies Ultra turnz module that does incorporate the Tourpak lights to flash with the 4 Way Emergency Flasher
I would recommend the Ridetime Ultra Turnz module over the HD # 69200042A harness
kd6kik
