Gear whine on CSC Conversion
rhino65
250+ Posts
Aug 14, 2016
263
49
Atwood, IL
Brian
Now that I'm getting in some ride time on my trike I'm noticing some pretty good gear whine from the gearbox/ diff area. Its got a 2009 CSC conversion with the gearbox on front of diff. Is a good bit of whine normal? At 70 mph its really singing.
Can't remember what CSC calls that design. But it like a 4x4 transfer case sitting on the side of a P/U transmission. In this situation, it's a small cast housing with some idle gears inside, and it sits to the right front side of the diff. It's purpose is to make the drive shaft more inline with the output shaft of the engine.
If that is the design you have, singing is not good. Do you have excessive clucking when shifting gears or throttling on/off at parking lot speeds ??? The off-set cast unit has a small drain plug in it's bottom ... remove it and look for metal in the oil, or no oil at all.
CSC has an updated shaft assembly that removes the off-set housing. Also, sometimes "singing" can be caused from cupped tires.
I drained fluid out of both gearbox & diff right after buying it. Called CSC to see how much to refill both. 1 qrt for diff & 6 oz. in gearbox or until it runs out check hole. To my surprise it was clean from both and not lo in either. Not getting any clunking & shifts smooth, even smoother not using clutch.
Replaced the driveshaft with one from Mountain Trike also. The CSC had slop in the shaft splines and rubber donut cracked SEVERLY in sevral places. Did a google search for CSC gearbox whine & some stated it was normal while others said shouldn't hear anything but wind. Kit does have 40k miles on it.
I have 08 csc cobra with the gear box remove it has no whine , I also have a 05 csc cobra with rubber drive shaft & the gear box it has no whine to it .
Rear tires are cooper cs4 that were put on new with conversion. Conversion has 40k miles on it. Tread is little more than 1/2 used up. Could certain brands of tires that are wore down by half cause a whine very similar to a gearbox?
Did your whine change at all with the fluid change ???
Does the whine change pitch when the pavement changes ???
On a trike, many trike shops recommend new tires when the tread is half worn. As the tread depth lessons, and because there is not a lot of weight on the tires, water can't escape as well under the tread face as when new, and the tire becomes squirrelly on wet pavement ... basically they began to float. It sounds like new tires are needed anyway.
I noticed it when I test rode it. Then for next 2-3 weeks I changed fluids, coolant, air filter, plugs along with new shaft from Mountain Trike. Thought @ $16500 it was good deal for 02 but live & learn. If worst comes to worse replace entire rear end. Its only $$
Yep .... if prone to ride in rain I'd say "not a bad idea" (might be easier "mentally" if the tires also fit your daily driver 4 wheeler). "Wife Unit" and I got caught in a sudden down poor one day, likely 3/4 of tread left on Lemans SR 215/70-15 rear trike tires, two up only (no trailer) reduced speed under 35 coming south out of Staunton, under overpass start up out of ever so slight dip, easy on throttle, RPMs went up and rear went to right and I countered ..... likely went a hundred feet like that .... already looking for a place to pull over, we did at SS Co-Op under their gas awning.
Only one other time
in my life I have had such a bad case of hydroplaning .... even in 31 years as a state police officer working in all kinds of weather responding in it .... and that was about 1971 in my '69 VW Beetle which had adapters on it for Chevrolet wheels and I had a pair of 14" wheels on back with then near new Sonic Maxima 60 G60-14 tires that stuck out the fender (pretty fat tire on rear of a light car, oem VW 5.60-15 on front) and at 45 mph in hard rain .... I suddenly was looking out the right vent glass at my direction of travel .... recovered .... but learned how easy it is with lightly loaded fat tires.
There were plenty of times as a responding officer I pushed the edge, but the car was heavy and I knew my tires and my roads.
Glad to hear CSC stepped in. I wanted to share more, but didn't since you'd already talked to them ... they know their product better then any other. I've always dealt with Shawn, and he's always given me great advice.
I talked with Will 1st week I had trike on how much gear oil diff and gearbox held as well as just being sure the 2 Allen head bolts on gearbox was to drain & check for when it was full..
CSC customer/tech support is A+++ Both Will and lady I spoke with were very friendly and supportive. Don't find that much anywhere else
Did they help you with your whine ???
After reading threads and posts about this gearbox added to straighten a driveshaft ... I gotta ask ..... "what was they smokin?" when they decided to add such complexity. Most every car's rear has the shaft slightly to right of center ..... like the output shaft on a GL trans. It can't be that far out of alignment that U-joints can't handle it.
Talked with Will @ CSC this morning. He said some noise is expected due to added gearbox & diff. I double checked my levels in both & all good. It pushes easily in neutral by hand. Shifts smooth,so for now going to ride.
May have they're new drivetrain version installed next fall/winter. It does away with the gearbox.
I'm working on one that has your design now, and I'll be doing a final test ride tomorrow. It's in for a major service and today I drained and filled the front area of the diff. I was surprised to see how clear the fluid was, my guess is that it was recently changed. I'll let you know what I hear, however, on my first test ride, I don't recall noticing any whine.
If it's possible I would like to know approximate mileage since triked. Also if gearbox & diff had thin film of grease/grime. Sprayed mine down with degreaser and rinsed off after getting it.
I had it done on mine last spring. Mine didn't have the gearbox but still had issues. This one is supposed to be the best one they've installed so far. To me it seems to be a better product then what I had before. If you take it to CSC it is supposed to take them a day to do it, at least that's what they told me. I took mine to an installer and it took them a day and half if I remember right. So you're really not down long if you pick the right place and well worth the money in my opinion.
I finished the service and took it for another test ride. There was no noticeable whine. I did notice what I would call double back-lash noise when letting-off and throttling-on that I would call normal. As a result, shifts can be a little clunky.
The owner bought this trike used, the mileage/age of trike is not known. However, the mileage on the ODM is 57k. And the kit is on a 2005 GL1800.
Yes ... the gearbox in the rear also has a film of oil on it. Not to the point that I would worry about it, as in something leaking. Oil could be weeping from the "silicone gasket" between the 2 gear boxes, of from silicone oil over spray ... or possibly the gear boxes come shipped with a film of oil on them when new. The oil film does not appear to be coming from any seals, or axel boots leaking.
Thanks Greg for the feedback. Still not sure what to think about gear whine or whatever it may be. Met another GW rider Sunday at my coffee bar. He was on a 04' 2 wheel Wing. His was noticeably quieter running than mine just idling. Between the 2 mine had more of a sing or whine to motor. Mines has 52k miles where his only 13k. IDK maybe it's motor whine I'm hearing.
Are you referring to a whine at idle or one that increases while going down the road ???
When going down the road. But after listening to one of about same year but considerably less miles it was quieter just idling. Hoping for a decent day when I can get out and rack up a couple hundred miles and really get a feel for it
Aside from regular oil changes the last service previous owner had done was at 39k miles which was rear diff, gearbox, clutch and brake fluids change.
Wondering if noise has always been there and just nature of it?
POS
If you are referring to a whine that you hear while at a stop, and with the engine running, it is coming from the engine area. The rear end has nothing to do with it since the rear wheels, and the drive shaft are not spinning.
By nature, GL1800s all have a whine coming from the engine area. More specifically, it mainly comes from a drive unit that drives the alternator. The alternator drive unit is called an alternator drive gear, and it's housed in the rear case directly in front of the alternator. Also know as a ADG. If you remove the chrome engine cover on the left side, you will see the alternator. If this is the whine that you are hearing, it should me loudest near the alternator.
What you might be hearing could be normal. The 2006+ years are usually whinier. However, the 2001-05 are whinny too, and if your Wing has ever had an ADG repair, the whine can be very similar to the newer years. A trained ear can tell the difference, and should be able to distinguish if your whine is normal and nothing to worry about. Most owners learn to "tune" out ADG whine.
We bought a 2010 1800 goldwing this past year with California Side Car trike kit on it. Was installed 3-11 according to Will @ CSC . Have around 11,000 miles on it now. Noticed every once in awhile when coming to a complete stop and using the foot brake it will make kind of a clunking sound but not a deep sounding clunk. Does this once and is fine. Might do it on next stop and might not. Should state that it makes the sound after coming to a complete stop and when just starting to take off from a complete stop.
Any ideas?
Didn't do this before Honda Brake Recall. But they looked it over and said everything looks fine and runs like it should. Won't make the clunk all the time is the weird part. Of course won't do it at dealers either!
Will @ CSC said the driveshaft weld service bulletin was done on 6-28-12.
I am wondering if it is the splines on the driveshaft.
What does one ask for if wanting the driveshaft update kit you guys are talking about?
Appreciate any help you can give me!
Any ideas?
Will at CSC should know what you are wanting by simply referring to update kit. It does away with gearbox and you get there updated automotive style driveshaft. Better mileage, rolls easier so I was told by Will
msshevlin
