Is there anyway to have the sound from a Garmin 350lm go to the Harley Boombox speakers ?
Like Nuc said can only do this with the Harley Road Tech versions of the Garmin GPS units . . . and even then it requires some hooking up to make it work since it is not supported natively by the Boom Box. Learned what to do a couple years ago and had my Garmin Road Tech Zumo 590 hooked up to pass prompts through the Boom Box on my '17 CVO Limited and now I have it working on my 2018 Tri-Glide.
If you want to spring for a Road Tech Zumo model I'll be glad to get the hook up details to you.
Hmmm..... I guess my question is: Why bother with the time, effort, and expense of adding a Garmin GPS when you already have the factory Nav system built into the BoomBox? I had a Harley Road Tech Zumo on my '09 Ultra and I really don't see where it was superior to the BoomBox Nav system other than the factory system doesn't show the speed limit.
