Udawg
80+ Posts
For those of you with an Apple Watch I just wanted to share this Door Opener trick. I realize a lot of you probably already have it but if not, it's a help when coming home. If you have a MyQ Smart Garage Controller (about $25 to $30) there is a file you can download from the app store called "Livekey". It allows you to setup an "OPEN" and "CLOSE" command to use in Siri. When approaching the garage just say "Hey Siri Open Garage" and the door opens for you and the same when leaving if you say "Hey Siri Close Garage". You can also setup a "Garage status" to see if it's open or closed. I know some of you just have the MYQ app programmed so you can use it but it just didn't work that well for me. Personally I don't have "Hey Siri" turned on because i don't want it listening to everything said around me 24/7 but it still works with the watch by just raising it and speaking "Open Garage" without the "Hey Siri". Just wanted to share for those that might be interested. You don't have to buy the "MyQ Home Bridge" with Livekey. Ride Safe!
