Can someone tell me where is the fuse for the battery charging cable? I put a meter on the cable and nothing, checked the 5amp fuse and it looks good. Is there a line fuse?
Do you have an Aux on your fuse box?
It could be the accessories fuse or the P&A fuse also if your tender is wired thru the factory wire harness
:clapping:Thank You,:clapping: it was the P&A fuse. Do you know what P&A mean?
