My Honda VTX1300 will go on reserve at 147 miles and 4 gals pretty muck like clockwork.
I have 2015 Freewheeler, and when I ride far and long my fuel warning light comes on. The reserve warning tells me I have 25 miles to empty. All that being said when I get to the fuel pump I can only put 4 gallons of gas. I took it to the HD where I bought the bike and the technician told me I had to learn my bike. Well that being said I told her I wanted my bike back since they could not fix it. There is something wrong with the computer system that controls the fuel data. Harley is so lazy to examine it, they just tell you take two aspirins, and ride. When I fill the tank after 4 gallons the reserve screen tells me I have 204 mile to empty. Doing the math at 204 divided by the 6 gal capacity I' m getting 34 mile to the gal. In which I fine with. The problem still not resolve because when I ride far and long I have the same issues. You are not alone! you cannot burp two gallons of air space from the tank. Harley needs to get off their A&& and provide their customers a real solution. until then good riding stay save, and don't run out of patience and gas!!!!![]()
Msocko is absolutely correct about running the tank dry. Very bad idea as the fuel acts not only as a lubricant but as a coolant. And cavitation is not good for any pump.
I've been looking at this fill problem since I first got the Tglide. I am working on adapting a piece of copper tubing that will extend just past the opening into the tank WITHOUT FALLING IN. This hopefully will allow the air to escape so the gasoline nozzle will not shut off prematurely. I think.
Come to think of it, the easiest thing to do may be to carry a small glass container that can be manually poured into the tank to finish filling the tank all the way. After having done this a time or two you'll likely know just how much to put in the bottle to finish filling the tank. The only other thing you may need is a small funnel and a piece of yesterday's newspaper to wipe the funnel out with.
PC
41 Replies about how much gas does the tank hold..Theres burping and shaking and rocking and nursing fuel in and McCuffing and Rube Goldberging... In my humble opinion the real reason some can't get 6 Gal's in the tank is the obvious.....
''Tank Shrinkage.''....
Are you saying her tank's not sanforized ?41 Replies about how much gas does the tank hold..Theres burping and shaking and rocking and nursing fuel in and McCuffing and Rube Goldberging... In my humble opinion the real reason some can't get 6 Gal's in the tank is the obvious.....
Are you saying her tank's not sanforized ?![]()
