How many miles should I expect out of my factory 2012 goldwing front tire once its tricked? I bought my bike new and had it converted out of the crate.so far I have 8300 miles on it.
How was your tire balanced? That could make a difference in tire wear.
Regards,
Rosy
From NH
Rosy, I am using the balancing beads in the tire. Will probably go with the Ride-On system next time.
If you have the auto pressure sending system on your trike, I am sure you can not use this product, is this correct?
Another question I have is, will the inside of your tire look like when you use Fix-A-Flat type product all googie, and dealers really get upset when they have to change the tire.
Another question I have is, will this product harden after so many miles, or will it still be fluid?
I have Dyna Beads in my tire and it rides great and I should get good mileage out of my MPA.
Regards,
Rosy
From NH
I just changed my front last month, this was my second front tire. The first on, which was the stock radial was only good fo about 7200 miles, the second one which was a MPA in reverse had over 25,000 miles on it and still had over half the original tread. The only reason I changed it was because of cupping, which affected the low speed steering. The cupping apparently came about because somewhere I lost the weights which were used to balance it. The current on is also balanced with weights, and the ride is extremely smooth.
Good info for a new trike rider, but a long-time motorcycle rider. Let me ask a stupid question....several of you have referred to an MPA tire. What is that? I've had all kinds of tires over the years but don't recognize that name, brand or model.
:Shrug:
T113
Rosy, Thank you for your thoughts. As it turns out, I have research the Ride-On product and found that your concerns have been taken care of or never really existed. I found it does not affect TPMS if used correctly. It does not solidify (or tire balancing will not happen) and the "goop" inside of the tire is radially dispersed and coats the inner circumference of the tire to achieve balancing and puncture sealing. If the tire has been sitting for a long time and the "goop" does get on the inside of the rim, it is easily removed. I got this information from their web site.
