Front Fork Brace: Super or Kury??
Nov 15, 2012
976
72
Delray Beach Florida
I did my research on front fork braces and I want one.
My question is basically this.
2 parter by the way.
1: Is there any benefit to the Super Brace over Kurys?
They seem the same cosmetically and they accomplish the same function.
The Traxxion is way out my price range for this type of addon.
As with my riser choices.
The MLB setup vs Kurys is in my opinion is superior to Kurys. Yet they too do basically the same thing too.
With MLB moving the bars inward also as a plus.
So I went in that direction there.
I was just curious what you guys might think.
Between the 2 choices above.
Then this as a possible option.
2: would a plain old 41mm fork brace do the same thing??
Much less expensive option if it would.
I had an aluminum tweek bar as we used to call them back in the day on a 12 inch over front end extention and it worked fine back then.
No flexing and very simple yet inexpensive fix.
On a side note saw my trike at the shop yesterday, reassembly is going well.
The whole rear had to come out.
The fix was a bit more involved then the guestimate.
Thanks in advance.
I am probably the most mechanically inept wrencher on the forum but I self-installed the SuperBrace with no problems and am well-satisfied with the results - a much more solid feel to the front end.
Good to hear no negatives to installing the brace.
Im guessing its just a matter of choice between brands as I can find no differences noted by anyone anywhere.
I just though this time it might be worth asking as it most definetly was in reading up on both the Kury and MLB riser kits.
Thanks folks
Ive made more then enough mistakes already.
corsair
