NHBAGGER
400+ Posts
Any of you running a custom front fender on your Tri? If so, pics?
You have probably seen this .It is a KlockWerks Benchmark.I will have pics in color a soon as my Avon Trike tire gets here.That rim is an 18" Harley Anarchy.Any of you running a custom front fender on your Tri? If so, pics?
Paul Yaffe Thicky, 21" wheel. I ran the fender like this for a while, I knew it was pretty low, tried to be careful. A few weeks ago I forgot and went over one of those rubber speed bumps, they are steep on both sides. Fender proved its strength, carved a chunk out of the speed bump. I then trimmed the lower rear edge a little higher, about an inch, and parallel with the ground.
thats a trick looking trike, awsome
first thing I did was get rid of that old boring front fender.. Thank goodness for Klockwerks,, they have many nice ones .. Harley needs to revamp the TG
Thanks for the compliments.
My goal was for it to be "not a geezer glide"...
