Front End
Oct 30, 2010
269
18
Tampa, FL
On my last ride, I noticed my front end had a slight ‘catch/sticking’ to it when turning the steering wheel. It felt as if something was binding in a spot, kind of like a bearing going bad. Is here any type of bearing in the triple tree area? Has anyone else experienced the same situation? I’ll call TMS if need be, but wanted to check with you guys first.
There is an upper and lower bearing in the steering stem, both are tapered bearings.
It is recommended that you have an authorized dealer take a closer look at the entire steering assembly to ensure there is not another issue causing this as well.
Similar threads
Delverc
