dthorn
40+ Posts
HI all
I will be getting my 2017 tri glide out of storage soon. I stored it at my local HD dealer. While it was there over the winter, I had a new front tire and front and back brakes replaced. I know that after about 100 miles I need to check the rear lug nuts. I already check them 3 or 4 times a season and know that torque spec (90 lbs. -100 lbs.) by heart. Its been a couple of years since I checked the front axle torque.
I remember the front axle as being 70 lbs. to 75 lbs. and the pinch nut 18 lbs. to 22 lbs. But I am not sure as my memory isn't quite what it used to be. I would like to check the front axle after about 100 miles when I check the rear lug nuts. It would be much appreciated it someone can confirm my numbers or if my mind has let me down to give me the correct ones. Thanks all
David
David
