Freewheeler Trike Trunk Lid Organizer
Put Saddleman organizer on trunk lid. Read available messages but wanted to see for myself. Adhesive strips, 3M heavy duty tape and 3M loop/link tape didn't hold. Made two holes on top of organizers and used two of the bolts from the underside of the luggage rack. Appears tight enough and holding, but will that pose a problem at some point? Thanks.
Don't see how. A flat washer on top of the organizer is probably a good idea and check them occasionally to make sure the bolts aren't loose, although a bit of locktite should help there. I like mine. Use it daily for light weight items.
Bolted mine using the luggage rack bolts and fender washers . 8 years and still there .:clapping: Did the same with the trunk door organizer .
Boatpaddle
