freewheeler and custom dynamics flasher
GLT
Sep 15, 2015
12
4
Bella vista
I have a 2015 freewheeler and I put a custom dynamics lb07 brake light flasher on and all it does is flash all the time. It is on all the time and it should only come on with braking only. I put one on my old trike put my old trike didn't have a can/bus light system. Any one no what is going on??
Wish I had an answer for you GLT. But calling the manufacturer might get you a quicker response.
Phu Cat
I can't help either, but custom dynamics has a video section that could possibly help you with the problem.
Did a little more research. If I've got the right one you are asking about, it has 10 settings. Maybe it is set on 9 which is constant. Look at your module for the switches. Only settings 0 thru 3 will work with incandescent system.
0-four flashes then solid
1-four flashes, solid for 3 seconds, repeat
2-seven flashes then solid
3-seven flashes, solid for 3 seconds, repeat
Pattern 0: Four Flashes then Solid (Incandescent or LED)[/LEFT]​
Pattern 1: Four Flashes, Solid for 3 Seconds, Repeat (Incandescent or LED)
Pattern 2: Seven Flashes then Solid (Incandescent or LED)
Pattern 3: Seven Flashes, Solid for 3 Seconds, Repeat (Incandescent or LED)
Pattern 4: Quad Strobe, then Solid for 1 Second then Quad Strobe (LED Only)
Pattern 5: Quad Strobe, Solid for 1 Second, then Quad Strobe, Solid for 3 Seconds, Repeat (LED Only)[/LEFT]
Pattern 6: Custom LED Blaster X Cycle for 3 seconds, then Solid (LED Only)
Pattern 7: Custom LED Blaster X Cycle, Repeat (LED Only)
Pattern 8: Max Strobe 4 Seconds, Solid (LED Only)
Pattern 9: Constant Max Strobe Pattern (LED On[/LEFT]​
Sorry, no help on your question but I was reading somewhere, recently, that brake-light modulators have been outlawed in many states.
Not sure how law enforcement would react when encountering a bike/trike on the street with flashing red light, in states that have outlawed them.:xzqxz:
Some folks might not care, as the theory behind the pulsing brake-light is that they help in preventing a rear ender...
I found the Ffx for me Lb07 flasher.
I had replaced my tail light blubs with LED's and I was getting voltage feed back from the LED's and that's why me custom dynamics brake light strobe was on all the time. Thanks to all for the feed back. GT
It was because I put LED':pepper:s in my tail lights and was getting feed back to the strobe light all the time. Thanks to all of you guys
:clapping: Good to hear you figured out the problem and shared the experience. It is a good *bit* of knowledge that could be very useful for future users of the equipment.
Pmdurant1966
