Fork question
Marc H
4250+ Posts
Gold Member
Dec 13, 2011
4,796
1,966
Evensville, TN
Marc
If I raise the front of the trike and pull forward on the wheel how much movement should I get.I realize in that position the bushings will be close together and i'll have more there than at any other position.
Marc
Your question is vague...
If you are talking about the fork tube and lower leg, any noticeable movement is a concern. It usually indicates worn bushings within the fork assembly.
If you are talking about the collective forks and triple tree movement, re-torque the stem or replace the stem bearings.
Thanks Lee.I was talking fork tube and lower leg movement.Thats what I was thinking.Mines not leaking but seems to have a good bit of movement there.
If there is any movement in the slider/Leg then you have worn bushings and should rebuild soon. Because of the forces placed on them trikes seem to wear these areas sooner the a 2 wheeler does.It won't matter if you have a raked/easy steer type front end or an unmodified you will still have more wear in the front end then a normal 2 wheeler.
Duke_germany
