fordmann
I can't here cause pipes are loud. Wife says it's a constant squeak when going thru th gears.
With the limited information you’ve given I’ll take a guess and say maybe the drive belt is loose and needs to be tightened up a little bit???
I'm still trying ta figure this out. Not good with comp. Just sarted to text 4 mo. ago. I'm 65.
Bear with me!!
squeeking
I hav pulled all th pins out of th a arms. Lightly greased n put back in. Also greased th splined shaft. No more noise. Would like ta thank who all helped. Great bunch of people.
Dieseluladstron
