Fog Lights on only w turn signal
Aug 17, 2015
87
19
paris
89' GL1500 Goldwing, Recent purchase, the fog lights only work with the blinkers on, How can i wire them to where they are on all the time,atleast at night
Might consider a relay. Then use low beam or other postive lead then to the battery. Might want to use one that operates off the switch. The turns will only let them flash, I would think.
Those are "cornering lights" on the 1500, not fog lights. They are directional to the side and would not make good fog lights at all. You will need to add fog lights if that's what you desire. I added driving lights under the forward fairing on my '97 SE
dyno56ca
