Fender Rails Lights
Dec 29, 2012
6
FL. US
Has anyone installed fender rail lights? I just purchased the rails and light kit and the directions are saying they plug into the connector under the seat. The lights should work with the tail and brake lights. I thought the plug under the seat was for accessories. Any help would be appreciated.
Look farther back inside the frame mounted on the left side. there is a relay for the tail, brake, & turn lights there. Put your hand through the hole under the passenger area. Be sure what side of the relay they want you to plug into. Before or after.... If the lights don't work right,,,, unplug & go to the other side of the relay. Also be sure of the ground. make sure it is to the frame.
:Trike1:
Trike down
