extra gas tank
:Coffee:[/FONT Looking for extra gas tank for rear of my trike.2008 Victory Kingpin/Lehman Pitboss Trike
welcome aboard. glad you joined us. Not many Victory trikes here yet. You may have to fashion one yourself. Good luck
I needed one for my Lehman Suzuki C90 Jackal. I got a 2.5 gal auxilliary tank from Gman Industries. It fits between the lower rails of the trike frame structure between the shocks just in front of the box. It's filled from the gas inlet and uses it's own fuel pump with a timer to transfer gas from the aux tank to the main tank. When you get to reserve you hit a toggle switch and the fuel pump runs for about 5 minutes transferring the gas. You don't even have to stop.The unit is made specifically for a C90 Jackal but, since your's is a Lehman, it might be worth a look. There may be a way to modify it to work with your trike. ThumbUp
GMan Industries
Boatpaddle
