MDF48
250+ Posts
The next week or so I am going to be installing a Kuryakyn Chrome extended brake pedal #9672, on my 2016 TGU. I have read a ton of post and watched a bunch of You Tube videos on this.
I have a few questions for those of you that have done this on WET HEAD 14 and up Tri Glides.
1: Did you have to loosen (or remove) the front floor board MOUNT bolt after removing the floor board? Most people say just loosen.
2: Did you absolutely have to remove the 2 bottom crash guard bolts and loosen the top one? Also, does that give you enough FORWARD play without damaging any of the hoses or lines connected from the frame to the lowers?
3: After removing the lower engine guard bolts and loosening the top bolt, does that give you plenty of room to complete the install?
4: Is it easier to fool with taking the cotter pin out after taking the master cylinder loose, or do you have to do it before you take it loose? I know it is a PITA either way.5: Did any of you have to loosen or take off the front heat shield on the front pipe? I saw some post where they said they did.
Any other helpful hints will be appreciated. The reason I am asking all of these questions is because I have read post or watched videos where some indicated having to do a lot more than others. TIA.
