Prepping the Free for its ride to Daytona. I want to put a larger fuse in the battery tender lead to run my mini compressor. I can't find it so I need some help. Pulled the battery cover off and I can see the negative (blk) wire running forward then getting taped up in a bundle to the shifter side. The positive (red) wire runs down and then is covered with flexible wire cover. The lead comes out toward the back of fuse panel and they had it zipped tied toward the header. Stupid place as it get roasted there so I had moved it when I first brought it home. Can someone direct me to where the in-line fuse is. Thanks.
matt
matt
