I've seen people mention a few times that they got "that $120 de-catted header from ebay" but I cannot for the life of me find the thing. Can someone point me in the right direction? A search term to use, something?
I saw a few, but none said they would fit the FLRT. I'm mostly concerned with the o2 sensor ports. Are those universal on the touring models?
I would have a problem with how well they get all
the honeycomb out. I did a few. It's time consuming if done right. I just got a new FW yesterday. This time I'm getting the Fullsac Sport. $399 then $100 core charge refunded when you send back your pipe.
The cats are down stream of the sensors.. So decating wouldn't effect them...
As far as fit thats a good question..:Shrug: Most of those are for the Tri-Glide..
So I've messaged 3 different sellers on ebay with these headers, and the 2 that have replied so far have redirected me to another listing (more expensive of course) that they have that specifically says it's for Trikes or Triglides.
Are they yanking my chain here or is the Triglide / FLRT actually a slightly different header?
The cats are down stream of the sensors.. So decating wouldn't effect them... As far as fit thats a good question..:Shrug: Most of those are for the Tri-Glide..
rhino 2,
The information you stated here is not correct. The cat is upstream of the o2 sensors.
The o2 sensors on the late model touring Harleys including the Freewheeler are behind the cat. The cat is in front of both the front and rear o2 sensors. Look at your header and you will see both the o2 sensors just behind the cat. The cat is just behind where the rear or back cylinders header pipe drops in to the header collector intersecting with the front cylinders pipe. All is covered by chrome heat shields.
The next thing you will see after the o2 sensors as the header pipe goes towards the rear of the bike is the cross over pipe connection going to the second muffler. Also there is only one cat in the factory header.
Ride Safe,
Bill G
I think we have a little confusion here. The cat is BEHIND the 02 sensors. 3.5 inches to be exact.
For those who have " de-catted" is there a noticeable difference in heat?
