DK Custom Products has run-brake-turn conversion kits
Jun 15, 2013
9,117
8,814
Red Banks, MS
RUN-BRAKE-TURN CONVERSION KIT​
This small conversion module will fit easily under your seat, behind the battery sidecover, or anywhere else you would like to put it with the included double sided tape.
Turns your stock rear turn signals into Running Lights, Brake Lights & Turn Signals.
No messing with resistors or load equalizers.
It will do the same with the DK Custom Streamliner Bullet rear turn signals. Click HERE to see them.
Works with turn signal bulbs, and some LED systems.
By converting your rear running lights/turn signals into brakelights you can delete your tail light, or leave it in place and be more visible.
save 10%
use coupon code: Turn-10
expires 2-19-2014
Similar threads
Gyl
