***DK Custom Products Convertible Comfort Lift™ for Tri-Glides***
Jun 15, 2013
9,404
9,943
Red Banks, MS
DK Custom Convertible Comfort Lift™
Levels the Height of the back of your Trike
~ Looks Better ~ Handles Better~ Rides Better ~
The Convertible Comfort Lift™ Kit replaces the stock shock mounts of your Harley Trike. It gives an increase of 1.25" at the shocks and 1.6" at the rear of the bike. This is the same as the Standard Lift Kit.
The Convertible Part: On some pre 2017's, and more 2017 HD Trikes, there can be a very close fitment between the swingarm and the exhaust with a full 1.25" Lift.
The Convertible Comfort Lift™ has a second set of mounting holes that allow you to try the full 1.25" lift first, and if there is a fitment issue, simply use the built-in secondary mounting holes. It takes 30 seconds to make the change!
The secondary mounting holes give you almost 1" lift at the shocks & close to 1.2" lift at the mufflers.
Simple & Easy. You end up with the Ideal lift for Your Trike, and all the benefits of a Comfort Lift™.
What is different about the Convertible Comfort Lift™ from the Standard Lift is they slightly change the angle of the shocks rearward on the swingarm. The suspension now absorbs more of the smaller and larger road imperfections, resulting in less of the bumps being passed on to the rider and passenger.
Net result is a Smoother, Plusher ride.
Click HERE for more photos and details!
dhinzman1
